Importing a picture into Encore 2
COW Forums : Adobe Encore DVD
Hector
on Apr 11, 2006 at 7:25:58 pm
When I import a still camera picture into En. 1.5 to use as a background, I can resize it to obtain the size I want. I tried this in Encore 2 but I couldn't find the way,
If is possible to resize a pictute within En. 2?
Thanks in advance
Joe Bowden
Re: Importing a picture into Encore 2
on Apr 11, 2006 at 9:34:19 pm
Make sure you are using the right tool: The black arrow is the button select tool- the arrow to its right is the direct select tool.
Use the direct select tool and you can manually scale the layer.
