Encore DVD 2.0 & Disc space
COW Forums : Adobe Encore DVD
davidnagel
on Mar 14, 2006 at 8:53:46 pm
Hiya, not your run of the mill file size issue, more of a lack of space to put file sizes!
I have a personal copy of Adobe Encore DVD 2.0 and have recently finished a 4 gig DVD project.
Getting to the Build panel and pressing Build begins the process, but Encore has other ideas. Encore believes that it needs to use drive D: which at the moment only has 1.1gb space left, but fails to see that drive F: has 13gbs.
How do I tell Encore to use drive F: instead of drive D:?
General preferences fail to show any field to change the temp folder location. Is there something I'm missing?
davidnagel
davidnagel
Re: Encore DVD 2.0 & Disc space
on Mar 14, 2006 at 9:01:21 pm
False alarm.
It seems Encore transcodes the files on the drive the project is saved.
Seems odd to me.
Anyways, please would an admin/mod remove these postings?
davidnagel
Rich Okonski
on Mar 15, 2006 at 5:44:07 pm
David, this posting is useful. I ran into the same problem and actually copied my entire folder onto my video drive instead of where I mistakenly set it by default, my system drive. I did not see a default path either, which would allow me to always select a given drive for rendering projects. Encore on the surface resembles the other Adobe products, but things seem a little off Adobe standard when you use it. Not a bad thing, but harder to figure out in some matters.
Rich O.
