CD ROM created in Encore DVD
COW Forums : Adobe Encore DVD
motiongrapher
on Mar 12, 2006 at 3:28:01 pm
I created a simple CD ROM, which was playing fine in my PC. When I played it in my VCD player (which is quite old), it was not playing. I guess this has something to do with the compatibility issue when creating the CD. Can someone help with the settings as to how to make it compatible even when played in older versions of VCD players ?
Thanks in advance.
S. Anand
aka Andy
Aanarav Sareen
Re: CD ROM created in Encore DVD
on Mar 13, 2006 at 7:21:36 am
VCDs are very different from DVDs. If you put the CD that you created in your DVD player, it should work fine. Unless, you specifically create a disc that meets the VCD-specs, it won't work
For more info: http://www.videohelp.com/dvd
