Tran
COW Forums : Adobe Encore DVD
Matt Fezz
Tran
on Feb 25, 2006 at 9:44:39 am
Hello, I am attempting to build a dvd for a project I have been working on for about 4 months. All has gone swell thus far, I have my motion menu's working and most of my clips transcoded, although when I attempt to transcode (either using the 'transcode now' function or when building the disk) my 'large' 1.5 hour, 20GB file, Adobe Encore 1.0 crashes about 1/2 way during the first pass.
This is extremely frustrating and I need to deliver tomorrow! Is there anything i could do to fix it? (I've tried about 5 times). Could any of you recommend a trial version or free download of a good MPEG-2 Transcoder (or encoder..I'm not sure what they are called) that would create a good quality PAL Widescreen MPEG-2 File?
I'm on a machine with 1GB RAM, athlon 2800+, and 50GB HD space
Thanks in advance
Mylenium
Re: Tran
on Feb 25, 2006 at 3:37:12 pm
You should try TMPEG (free, but difficult to tame) or the standalone version of the MainConcept Encoder (which is basically what Encore and After Effects use). It will run as a 14 day trial. I'm sure you could find other options if you do a little searching.
Mylenium
[Pour Myl
