Transcode setting
COW Forums : Adobe Encore DVD
Vegard
Transcode setting
on Feb 23, 2006 at 11:41:20 am
Hi again, I've always used the 'automatic' setting, which has been on 4MB VBR 2 PASS, with good results. However, this last time (as it was a s16mm project), the quality seems noticably worsened in the transcoding process. I'm just wondering if there are any reasons why I shouldn't manually choose the higher bitrate 7MB VBR 2 PASS? Will it be compatible with all players?
Jeff Bellune
Re: Transcode setting
on Feb 23, 2006 at 12:47:26 pm
Automatic transcode settings in Encore are moving targets, based on the amount of video material in a project. It's not permanently set to 4MB or 7MB or anything else.
Are you possibly referring to the default preset that appears when you open the Transcode Settings dialog?
-Jeff
Vegard
on Feb 23, 2006 at 12:56:46 pm
Ok, yes you are right, I assumed what was shown in the settings when I opened the dialog box was the 'automatic setting'.
So since I only have about 40min of footage altogether, I should just keep it on automatic, and it should be choosing the best settings for me?
Cheers!
Vegard
Jeff Bellune
on Feb 23, 2006 at 4:52:34 pm
Yes. Encore's automatic transcoding does a great job.
