Trimmed timeline problem
COW Forums : Adobe Encore DVD
Vegard
on Feb 23, 2006 at 11:14:18 am
When I trim the timeline, f.eks. so it starts after the countdown "2", the next time I start the project, the trim will be changed, and the "3" is even included. This is very annoying, is there a way to fix it? I'm using Encore 1.5.
Jeff Bellune
Re: Trimmed timeline problem
on Feb 23, 2006 at 12:42:06 pm
Are you trimming an mpeg file that has already been transcoded? There may be an issue with where the closest GOP to your trim point is in the transcoded file. AFAIK Encore can only trim to I-frames at the beginning of GOPs.
-Jeff
Vegard
on Feb 23, 2006 at 12:53:13 pm
Hi, thanks for replying.
But no, I trimmed it before I transcoded..
Vegard
Jeff Bellune
on Feb 23, 2006 at 4:51:59 pm
How close is the trimmed point to either the original beginning of the clip or the next chapter point? There needs to be at least a half-second between them (about 15 frames).
-Jeff
Vegard
on Feb 24, 2006 at 1:17:10 am
About 5 seconds (!)
