error when burning
COW Forums : Adobe Encore DVD
joefeng
error when burning
on Feb 14, 2006 at 9:43:57 pm
When I started a burn, I get the following error:
operating system error: number=0x00000020 - The process cannot access the file because it is being used by another process.
I have nothing else open...Please help!
Aanarav Sareen
Re: error when burning
on Feb 14, 2006 at 10:08:56 pm
Are you using Encore 2.0 or Encore 1.x? Also, do you have any other Adobe apps running in the background?
joefeng
on Feb 14, 2006 at 10:23:47 pm
I'm using 2.0.
I had photoshop running the first time when I got the error. Then I closed everything else and tried again, still got the error.
mark harvey
on Feb 15, 2006 at 12:23:23 am
I get these errors sometimes with other software...I always find it a good idea to do a shutdown before burning a DVD...I also make sure that any antivirus software is closed.
Mark
(Have not yet had this issue with Encore using the above method)
joefeng
on Feb 15, 2006 at 4:08:36 pm
I went in and manually deleted almost all the temp files in the project folders created by Encore for the project. Basically deleted everything I could with Encore still able to open the project. Then it asked me to re-locate all the media files and reimported them. After all this, it was able to burn again.
dominique44
on Feb 27, 2006 at 6:35:02 pm
Hi
I have the same problem , What have you deleted in the encore project ?
the sources folder or the cache folder
dominique44
on Feb 28, 2006 at 10:34:29 pm
After many checking, I must erase the folder transcribes to be able writing on the dvd or folder without error.
It's a other bug for encore dvd 2.0
dominique
sam yohannan
on Mar 23, 2006 at 11:42:14 pm
SO can anyone tell me exactly what files I need to delete in prder to get this error to go away?
