Using Encore to create a DVD from an Avid Sequence
COW Forums : Adobe Encore DVD
Bauce40
on Feb 3, 2006 at 5:40:21 pm
What is the best and fastest way to author a DVD using Adobe Encore from an Avid Sequence? I was testing Encore out with a 36 minute video edited in my Avid Xpress Pro system. I exported the sequence to a Quicktime Movie and have been transcoding the sequence for a couple of hours only to get an error message. Is there a fast way to do this or does Encore really only work with Adobe programs?
Timothy Kurkoski
Re: Using Encore to create a DVD from an Avid Sequence
on Feb 3, 2006 at 5:50:02 pm
Encore 1.x doesn't work especially well with QuickTime files. (2.0 is better with them.) If you can export an MPEG-2 file from Avid, that would be best. Otherwise, try using an AVI file.
Mikey W
on Feb 3, 2006 at 10:42:03 pm
I export from Avid Xpress Pro as an AVI. Seems to work OK, EXCEPT when I'm exporting a 16x9 image. Can't get Encore (1.5) to recognise the widescreen format. If I export from Avid as 720x576 then (obviously) Encore thinks it's 4x3. If I export as 1024x576 then Encore won't import the file and tells me that I need 720x576. If I'm doing something wrong, someone please tell me.....
Aanarav Sareen
on Feb 4, 2006 at 12:08:41 am
Encore DVD only supports full NTSC and PAL resolutions at the moment (720*480 and 720*576) and hence the error while supporting 1024*576
But, out of curiosity, why are you using this resolution anyway?
Mikey W
on Feb 4, 2006 at 7:44:11 am
Purely out of desperation. I appreciate that it's not correct, but my adventurous spirit got the better of me.....
pena
by
on Feb 5, 2006 at 9:53:40 am
Activate your AVI > right click > Interpret Footage > Conform to widescreen.
Mikey W
on Feb 6, 2006 at 10:50:19 am
Thank you. That's exactly the answer I needed.
Peter Mitchell
on Feb 9, 2006 at 2:01:19 am
I'm using an Avid MC Adrenaline (v2.16) and have "Send to" configured to open Encore. I export and encode QT reference files, both PAL and NTSC. No problems so far with programs up to 24 min in length.
Bauce40
on Feb 9, 2006 at 4:57:36 pm
what settings do you use when using the "Send To"? how long does it usually take to export and import your files?
