Best audio format for DVD...
COW Forums : Adobe Encore DVD
jhunyadi
on Jan 27, 2006 at 6:06:31 pm
(I'm rendering from AE)
Okay, from what I've read, PCM is the better option over MPEG audio - but multiplexed or not? If not, then you import 2 assets and put each on the timeline... Any sync problems with this? I'm just curious what the big difference between the files would be. Someone said the audio is not as good if you multiplex before Encore...? Can anyone shed some light on this? Thanks!
Joe Bowden
Re: Best audio format for DVD...
on Jan 27, 2006 at 7:34:09 pm
Encore prefers separate video and audio streams (the exception is AVI, which is usually video and audio interleaved). Separate streams will not introduce any sync issues, unless there are issues with video and audio sync before importing into Encore. Preferred audio format is PCM WAV, 16-bit 48kHz.
