Encore 2.0 and Encore 1.5: Project compatibility?
COW Forums : Adobe Encore DVD
Brian SaenzDeViteri
on Jan 18, 2006 at 12:58:24 am
Does anyone know if Encore 2.0 will be able to open Encore 1.5 projects without issues? Is there an import feature that can make this work? Just curious...
Also, is the Photoshop menu compatibility the same as Encore 1.5 - layers, buttons, etc. in Photoshop translate directly into Encore? Or are there different commands that are necessary and changes to be made to existing templates?
Joe Bowden
Re: Encore 2.0 and Encore 1.5: Project compatibility?
on Jan 18, 2006 at 1:02:44 am
Encore 1.5 projects are supported. However, once saved in Encore 2.0, they can't be re-opened in version 1.5. If that's important to you, SaveAs your 1.5 project in 2.0- then you'll be able to open the original project in 1.5 if needs be.
Photoshop support is pretty much the same, except added support for some Photoshop CS2 features.
Brian SaenzDeViteri
on Jan 18, 2006 at 11:39:50 am
Thanks for the info!
