Fed up with Encore
COW Forums : Adobe Encore DVD
austin
Fed up with Encore
on Jan 13, 2006 at 8:10:50 am
Hi!
I
Mike Cohen
Re: Fed up with Encore
on Jan 13, 2006 at 7:38:14 pm
What is your source? DV25?
No offense, but if you think a program is crap, try something else. This forum, however, can often shed light on these types of issues.
Mike
Bryan Carvajal
on Jan 14, 2006 at 2:35:19 am
i found that Encore's built in encoder does a good job, however its slow as a snail even on a p4-3ghz with 2 gb of ram. Think thats fustrating, wait til you manually do subtitles for your project. it makes the who program slow down to a crawl to the point where it makes you want to pull your hair out :( I've had a few crashes and corrupt files because of this :_(
Tim Wright
on Jan 14, 2006 at 4:07:40 am
I just switched over from DVDit PE and Encore is WAY BETTER! Big Suprise-Not.
Anyway, I do my encoding with Canopus ProCoder, and Encore leaves it alone, only transcoding the audio to AC3.
So far I like it.
Tim
Graham Quince
on Jan 16, 2006 at 8:56:02 am
If you're having trouble with Encore subtitles, try Subtitle Workshop. It's freeware, incredibly stable, easy to use and exports as a text file in the Encore format.
Graham
http://www.qcit.co.uk - web design
http://www.shiveringcactus.bravehost.com - Free FX for amateur films
