optimized encoding settings?
COW Forums : Adobe Encore DVD
Jega
by
on Jan 9, 2006 at 10:55:16 pm
hi
ok i have video files taken from my sony DV cam and they're about a gig in size each.
I was wondering how i can burn these to disk using encore and/or Premiere pro whilst retaining the highest quality possible and making the aspect ratio fit to PAL television.
What settings should i be using to get the best?
thanks ppl!!!
Timothy Kurkoski
Re: optimized encoding settings?
on Jan 10, 2006 at 3:09:55 am
1 gig is about 5 minutes of DV video. Is that how long each of the files are?
At that length, you'll have no problem using the max bitrate setting for DVD-legal MPEG-2 files. But for compatibility with all DVD players, I'd recommend you top it out 7000 Mbps. It'll still look great at that rate.
Jega
by
on Jan 10, 2006 at 12:38:48 pm
should i use automatic transcode settings are select custom settings.
Also will the video fit my PAL tv screen when using these settings?
thank you!
Timothy Kurkoski
on Jan 10, 2006 at 8:27:42 pm
The automatic settings will be fine. Is your DV camera a PAL camera? If so, then yes.
