Making a DVD that starts immediately (no Menu)??
COW Forums : Adobe Encore DVD
jeffrey fitzgerald
on Dec 19, 2005 at 4:08:04 pm
How would you make a DVD that does not use a menu in Encore?
David Garrett
Re: Making a DVD that starts immediately (no Menu)??
on Dec 19, 2005 at 8:23:17 pm
right click on the project window and then select "import as timeline", navigate to where the video file you wish to use is located, Encore will now import this and place it on it's own timeline. If there is no yellow circle with a triangle on the top left corner of this timeline (in the project window) then right click it and select "set as first play" from the pop up options. If you want this video to loop back to the start after playing then set the "LOOP" to forever from the properties of the timeline..
