Animating buttons
COW Forums : Adobe Encore DVD
D&D Digital Creations
Animating buttons
on Dec 5, 2005 at 4:43:34 pm
Hi, is there a way to animate non video buttons in Encore? For example, can you import a animated .gif file of a play button that changes color?
I'm guessing you can use after effects but that seems timely just to make a button dance..
Timothy Kurkoski
Re: Animating buttons
on Dec 5, 2005 at 8:41:04 pm
You can't import animations and make them a part of the menu, no.
But there are a couple of workarounds:
1. Use After Effects, like you've mentioned. You can also use Premiere, or any application that allows you to create a movie file. Because that's what you'll be creating- a movie file which is the background of your menu.
2. Import your animated button as a DVD-legal AVI, QT, or MPEG. Make a timeline out of it. Link to the timeline from your menu using an animated video button. Then customize the button routing on the menu so the user can never actually get to that button with the remote. (You won't be able to stop them from clicking on it with a mouse, though.)
© 2018 All Rights Reserved
