Menu button activation and non-smooth transition to animation menu fade out... help
COW Forums : Adobe Encore DVD
jimmilina
on Nov 28, 2005 at 10:15:38 pm
a tiny problem, but an annoying one.
Encore 6.0
I have a menu with two buttons. Each button links to a film clip of the menu fading out followed by its unique followinbg clip.
However, when the button is clicked [in preview mode] there is a flash of black or a single frame of black occurs and instead of a smooth menu fade out and then into another clip... it jerk-flashes this black screen first then continues.
What's the deal? How can I fix it?
...jim
David Garrett
Re: Menu button activation and non-smooth transition to animation menu fade out... help
on Nov 29, 2005 at 9:07:27 am
the dip to black should'nt be so noticeable on the burned disc. Try using a DVD RW disc just to check all is ok before you commit to a DVD R disc.
You mentioned Encore 6.0!!! Encore is only at version 1.5 at this point in time
jimmilina
on Nov 29, 2005 at 8:06:43 pm
thanks a ton. i'm a bit new with Encore and just getting into the 'fancier' treatments.
thanks again, i'll try it.
...jim
