on importing PAL quicktime into encore...
COW Forums : Adobe Encore DVD
robdelange
on Nov 22, 2005 at 10:26:43 am
hi here, a encore newbie here..,
i made some short clips in Avid Xpress DV and
exported them as 720x576 quicktime's, now when
i try to import them into Encore it say's that
they have to be 720x576, but the are !, what goes wrong?
Timothy Kurkoski
Re: on importing PAL quicktime into encore...
on Nov 22, 2005 at 5:23:38 pm
The error message is slightly off, I've seen it do this before. Encore sees something wrong, but the only error message it knows to put up is about the frame size. Something else is likely wrong with the file, such as the pixel aspect ratio, bitrate, frame rate, etc.
robdelange
on Nov 22, 2005 at 9:21:00 pm
thanx, i checked the spec's of the quicktimes again
and i think i found someting, somewhere in the movie export
settings i found in the box "motion" an option "frame reordering"
i't was turned on by default, i turned it off, and now it seems to
work !!
