DVD Encore - remote menu problem!
COW Forums : Adobe Encore DVD
harpervl
on Nov 5, 2005 at 10:29:12 pm
I have a project with a First Play and then 2 menus with different clips established with a video button. I actually made a diffferent project with
just the line banner button with the clips linked to them.
The first play clip works fine - The 1st. menu comes up and the 1st. clip has it's select arrow highlighted. It will play. The problem is, I cannot get my DVD remote menu to activate the other buttons. None of the remote down -up - over etc., will move to any of the other buttons to select them to play.
I have tried two seperate DVD players with the same results. If I play the DVD in my computers, they work great. When I mouse over the buttons, the select arrows work fine. I can jump between the menus just fine.
Any ideas would be appreciated.
V. Harper
Joe Bowden
Re: DVD Encore - remote menu problem!
on Nov 5, 2005 at 11:15:51 pm
Check your button routing...sounds like something is off. If necessary, you may need to manually route the buttons.
harpervl
on Nov 6, 2005 at 2:15:38 am
Joe,
Thank you for your info. I checked the routing. I had automatic
routing on but it did nothing. I turned it off, set the routing manually and tried again to nothing happening. I then went back in
an turned automatic routing back on, leaving the manual setting on.
That seemed to work. I find Encore a bit odd to work with.
Directions via manaual leave a bit to desire.
Thanks again for the input.
V. Harper
