Problem with the black spot between menus and transition between them
COW Forums : Adobe Encore DVD
Camoflage
on Oct 30, 2005 at 1:56:43 am
Sorry about posting this directly but I'm in a hurry with my problem. It checked other posts but I think this is the fastest way to get response.
Okay I'm trying to do menu with large photoshop file. I have split it to the menu sections and done transition videos from the movement between the menus. When I try to put a menu then it's end action to the transition there's a black spot between menu and transition.
I should get menu without that because it looks awful with that. I know that the black spot is problem from dvd format itself but I believe there's a way to solve this problem.
I got an advice to do it with only menus. Menu 1 would be the menu that starts the whole thing. Menu 2 would be a motion menu with transition. Menu 3 would be the menu that the transition ends.
I put the end actions and loop points and everything. Then I tried to preview put encore said unknown error and some numbers.
Does anybody know what could be wrong?
I pretty new for using this program but I'm in a awkward situation because I have to do this menu ready in couple of days.
Every help possible is greeted.
D.Fokker
Re: Problem with the black spot between menus and transition between them
on Nov 1, 2005 at 10:59:41 am
this 'problem' should only be in preview mode in encore.
Burn a dvd-rw and check in a standalone dvd.
The black flashes shoudn't be there.
Succes. D Fokker
Nomar Knows
on Nov 9, 2005 at 1:17:56 am
You should check if you made sure that the opening menu is "Set as First Play" and then try previewing it.
