Abnormal condition when I set an intro video to first play
COW Forums : Adobe Encore DVD
artdog
on Oct 25, 2005 at 9:40:22 am
I have a simple project with two timelines and buttons to play each timeline. Everything works fine. I created an intro video with After Effects and encoded it with Main Concept into an mpeg with no audio. Encore seems to like the mpeg as I can set it to don't transcode but I get the same problem even if I use the uncompressed video straight from after effects.
When I set the intro video to first play and try to preview, I get the dreaded "abnormal condition" error. As soon as I switch back to the menu as first play, the problem goes away. I am at a loss to figure out what the problem is.
Timothy Kurkoski
Re: Abnormal condition when I set an intro video to first play
on Oct 25, 2005 at 4:48:11 pm
What happens if you set one of your other videos to first play. Just as a test.
If that fails, too, I'd suspect something wrong with the project. Try starting a new one and rebuilding and see if that helps.
Matt Dubber
on Oct 25, 2005 at 7:52:55 pm
posted also at DMN:
Are you setting the video file as the first play, or the timeline containing the video? Be sure that the first play is actually a timeline and not to a video clip. This may solve the problem.
-Matt
