Monitor window disappeared...
COW Forums : Adobe Encore DVD
R. D. Hamilton
on Oct 17, 2005 at 3:31:06 pm
Is there any way I can get it back? I have tried resetting to the default setup, but that doesn't seem to help. Is there a preference file anywhere that I can trash? I believe the monitor window being gone has everything to do with the fact that I was using two monitors at one point, and my monitor window was on the second monitor. Now that I am using one screen, the monitor window is "lost".
Hector
Re: Monitor window disappeared...
on Oct 17, 2005 at 3:57:51 pm
Easy... just go to top header, click window and look below for "MONITOR".. click on it and Voila...
R. D. Hamilton
on Oct 17, 2005 at 4:56:04 pm
Yeah, I have done that several times. It activates...but the monitor window is gone somewhere. Any other suggestions?
Steve Freebairn
on Oct 17, 2005 at 6:11:19 pm
Maximize encore dvd, then try to reset to default, if this doesn't work, hook up the second monitor, move the monitor window and then save your workspace, then you can recall it whenever.
Hector
on Oct 17, 2005 at 7:52:52 pm
No other thing to think. What are you doing when this happen?
