putting mpgs into one timeline
COW Forums : Adobe Encore DVD
Jimmy D
on Oct 13, 2005 at 7:36:01 pm
I want to place some mpg files into one timeline but I just can't make it to work. Using still images it works ok. I create a folder then place the images in it. Then create a timeline, select all the images and it goes nice, the pictures are all placed one after the other into one and only timeline. But when I try to do the same with multiple mpg files it simply doesn't work. Am I doing something wrong? I 'm using Encore DVD 1.5.
Joe Bowden
Re: putting mpgs into one timeline
on Oct 13, 2005 at 7:48:28 pm
Encore does not support multiple video clips in a timeline.
Sorry,
Joe
Matt Dubber
on Oct 22, 2005 at 6:49:18 am
YOu can uses a third party program like TMPG MPEG Editor to create one MPEG file out of several. It's fairly inexpensive and works like a charm. It doesn't re-encode the whole file so the output quality is exactly the same as the source files. It only re-encodes the few frames where the files join.
-Matt
