Is it possible to convert a divX file to DVD format along with subtitles?
COW Forums : Adobe Encore DVD
DanielHaskett
on Oct 1, 2005 at 6:23:56 pm
Hi there
Basically I have a divX file that has a separate subtitles file. Now in WMP this works fine as it finds the subtitle file in the same directory and so plays it with subs. However is there a way of burning this file to a DVD with the subtitle option on them? Does that make sense? Normally I use WinAVI video convertor to change my divx to dvd but i dont know how to include subtitles?
I hope this is the right group! Dont know where else to post...
cheers
dan
Elad Menashe
Re: Is it possible to convert a divX file to DVD format along with subtitles?
on Oct 1, 2005 at 6:30:16 pm
I didn't understand from your post if you're using Adobe encore or not
The main question is whether you want to add the subtitles permanently for your file (meaning that the subtitles are part of the video) or you want that in the dvd you'll have the option to show subtitles
please specify which is the option you're seeking so I'll know how to answer your question
Elad
DanielHaskett
on Oct 1, 2005 at 7:38:22 pm
Hi there,
I basically want to have the subtitles....embedded or as an option. Its for a foreign film, so embedded is probably best. I can use encore, but it wont take divx files will it?
cheers
dan
Elad Menashe
on Oct 1, 2005 at 8:49:14 pm
Hey Dan
I'm quite new to Encore, haven't tried to add DivX files
But since you wanted permanent embedding here's a link that shows how to do it:
http://www.videohelp.com/forum/userguides/87065.php
it does not uses Encore at all, rather VirtualDub and VobSub
if you have any question please send me a mail since this issue is no longer related to Encore DVD
Elad
garg@netvision.net.il
