HELP!!!!!!!!!!!! SUBPICTURE NOT ACTIVATING when using MOTION MENUS!!!!!!
COW Forums : Adobe Encore DVD
Jordan Oplinger
on Sep 1, 2005 at 6:41:56 pm
HELP!!!! I've pulled out almost all my hair trying to figure this out.
I created an intro in After effects, the loop point is set correctly. Buttons and subpictures work perfect when the motion menu isnt rendered, but once I render it and preview, the subpictures no longer work. No highlights. the buttons work, but no highlights!!!
Cheers,
Jordan
Joe Bowden
Re: HELP!!!!!!!!!!!! SUBPICTURE NOT ACTIVATING when using MOTION MENUS!!!!!!
on Sep 1, 2005 at 10:48:26 pm
If you created the motion menu in AE, you shouldn't have to render in Encore.
Go to the Encore Layers palette, open each button layer set and hide all layers in the menu.
Does that work for you?
Jordan Oplinger
on Sep 2, 2005 at 4:32:02 am
I've tried everything. Even video straight from Premiere, used a motion background, the subpicture's don't work!!!!
Please help me!
-Jordan
Jordan Oplinger
It WORKS!!
on Sep 2, 2005 at 5:01:28 am
Ok, sorry about the panic!
I figured it out! I don't know what the problem was/is, but I burnt a DVD, played it, and the menus and highlights come up perfectly!
So if anyone ever has problems seeing the highlights infront of a motion menu, burn out a test dvd and check it out.
Well, there's two days of my life I'll never get back.....
-Jordan
