End Action for Timelines not linking to correct Menu button
COW Forums : Adobe Encore DVD
James M
on Aug 28, 2005 at 10:16:28 pm
I have a submenu with 10 menu buttons with each button linking to a different timeline (1-10). when i try to set the end action for each timeline to link to the submenu button for the following timeline, Encore choses a different link. For example, rather than the end action for timeline one linking to menu button two for timeline two, Adobe chooses menu button 6 for some bizarre reason. This happens for each of the time line end actions. each time Adobe chooses a different end action than the one i gave it.
Any ideas? Each menu item numbering is in sequence form 1-10 and i also have a "Main Menu", and "Next" button as well, numbered 11 and 12, respectively.
Ducati
Re: End Action for Timelines not linking to correct Menu button
on Aug 30, 2005 at 12:21:48 pm
First of all you should update your encore to the latest update. Then you can try doing an override on the links. Or you can try to start a new projekt and start all over again. This has helped me many times with encore.
