Button Help
COW Forums : Adobe Encore DVD
Matthew Press
Button Help
on Aug 10, 2005 at 4:01:28 pm
Hi Guys,
I'm making 3 Buttons using live footage in each. Very simple.
My problen is the footage only plays for 15 seconds in the Button Frames no matter what duration I give the menu. Actually if I give the Menu a 30 Sec. duration the footage freezes at 15 sec. till it reaches the 30 sec duration and then loops back. How do I get the Whole film to play in the Buttons?
Matt
Joe Bowden
Re: Button Help
on Aug 10, 2005 at 4:10:48 pm
Try this: create a video background (it could be just a static menu background - turn off 'Optimize Stills' if you're using PPro) that is the length of the duration you want. Or it could be a silent audio track, just make it the duration you want.
Render motion menus and you should get what you are looking for.
Matthew Press
Re: Button Help
on Aug 10, 2005 at 4:31:47 pm
Joe I'm not sure how this helps the duration of video playing as a Button.
Matthew Press
Re: Button Help
on Aug 10, 2005 at 4:48:34 pm
Joe I tried the Audio Trk under the Menu trick and that worked perfectly.
Thanks for your help.
Matt
