video banding / jitter
COW Forums : Adobe Encore DVD
jason philippy
on Aug 5, 2005 at 12:17:54 pm
I am exporting a video from avid express 4.6 on a windows machine. I've tried a variety of settings on the export, Quicktime DV, sorenson, component, quicktime meridian compressed and am getting this video banding look to the video after I burn it to dvd. The settings I'm using to transcode are:
Codec: MainConcept MPEG Video
Quality: 5.0 (high quality)
Frame Rate [fps]: 29.97
Field Order: Lower
Bitrate Encoding: VBR, 2 Pass
Minimum Bitrate [Mbps]: 5.0615 (medium quality)
Target Bitrate [Mbps]: 7.6173 (high quality)
Maximum Bitrate [Mbps]: 9.0000 (high quality)
M Frames: 7
N Frames: 14
as well as the default 7mB 2 pass setting. Why is this happening? am i missing a step. please HELP..
drumrob
Re: video banding / jitter
on Aug 5, 2005 at 5:34:20 pm
Jason,
Have you tried setting the field order to "Upper First"? Most AVID systems I have worked on use that as the default.
Have fun!
Rob
Rob Neidig
R&R Media Producttions
Eugene, Oregon
jason philippy
on Aug 5, 2005 at 6:29:35 pm
Yes I have....
still the same result
Timothy Kurkoski
on Aug 5, 2005 at 8:52:23 pm
Try reducingthe M and N frames to bare miniumum. I think 2 and 8 is as low as you can go.
jason philippy
on Aug 8, 2005 at 4:37:45 pm
That seemed to lessen it, but it is still there. Is it because my bitrate is to high?
Set Apart
on Mar 24, 2006 at 4:24:35 am
Jason, did you ever get the problem fixed? Jitter/shaky Video?
