DLT drive not recognised
COW Forums : Adobe Encore DVD
BazinoZ
on Jul 11, 2005 at 11:52:32 pm
I have 2 totally separate computer systems running Adobe Encore each with Quantum DLT4000 drives. In both systems the DLT drive is not recognised by Adobe Encore but show up in the device manager. They also test OK using Xtalk... so... anyone else had this problem and found a solution?
Dave Friend
Re: DLT drive not recognised
on Jul 12, 2005 at 2:36:30 pm
BZ,
I had the same problem. The solution was to reinstall Encore with the DLT drive connected and turned on. It seems that Encore assumes that if the DLT isn't there at the install it never will be. Dumb.
Dave
BazinoZ
on Jul 13, 2005 at 8:29:42 am
Thanks Dave but I had already done that to no avail....
cheers
