rough playback
COW Forums : Adobe Encore DVD
john morrell
rough playback
on Jul 5, 2005 at 5:26:06 am
I wonder if anybody can help me: I am making dvd movies which play back very well on my pc but when they are played on a dvd machine the vision is very jerky. I don't know what I'm doing wrong.
With thanks
john morrell
Timothy Kurkoski
Re: rough playback
on Jul 5, 2005 at 5:22:55 pm
* Try different media. Try -R instead of +R or vice versa. Try a different brand of discs.
* Keep the bitrate of your video low. Some DVD players (mostly older models) have problems reading video from burned DVDs that exceeds about 7.0 Mbps.
john morrell
Re: rough playback
on Jul 6, 2005 at 6:28:19 am
thanks for the reply. I'm using dvd -r disks and have tried a number of different brands and the bit rate is lower than 7.0 mbps, but the problem seems to be just with adobe encore. I have movie factory 3 and it does not show the same problem. I like the way encore is put together and how it produces the dvd (menues etc) and would like to keep using it if I can fix this issue.
john
Timothy Kurkoski
Re: rough playback
on Jul 6, 2005 at 5:46:16 pm
How many set-top DVD players have you tried? Some players, mostly older ones, have troubles reading burned discs. You should always test your discs on as many players as possible. A good trick is to go to an electronics store and try all the models there.
