Working with Playlists
COW Forums : Adobe Encore DVD
Matthew Press
on Jun 7, 2005 at 3:39:27 pm
Is there a Tutorial on the use of Playlists. I cannot get a handle on this.
Matt
Timothy Kurkoski
Re: Working with Playlists
on Jun 7, 2005 at 4:00:47 pm
There aren't any tutorials I've seen (but then again I'm not all-knowing). What about playlists is causing you problems?
Playlists are pretty simple, really. All they do is play a group of timelines in the order you specify. The big deal about them is that they free you from the tedious work of setting up a bunch of overrides to accomplish the same thing (see my Encore 1.0 tutorial on setting up this kind of structure manually).
You may want to watch Daniel Brown's videos over at the Adobe Evangelists site to get a better grasp on overrides and other Encore topics. (Sheesh, this link gets used so much we should probably get it posted at the top of the forum.)
David Garrett
on Jun 7, 2005 at 4:51:30 pm
check out this site, and take your pick :-)
http://www.sitesled.com/members/doogs/downloads.htm
Matthew Press
on Jun 7, 2005 at 5:39:19 pm
Thanks guys. Big help as usual.
