Update problem for 1.5.1
COW Forums : Adobe Encore DVD
Chris
on Jun 7, 2005 at 6:22:06 am
I am trying to install the 1.5.1 update but the install is not working. It says to specify the folder and I am but the error is that it needs to be where the Encore program is installed. There are no folders per se, but the exe file is in the directory I am specifying.
Any thoughts on this?
The computer says to reinstall from the disc which I have done to no avail.
I gotta get this DVD out as I am under a few film fest deadlines.
thanks
Chris
R. Hewitt
Re: Update problem for 1.5.1
on Jun 7, 2005 at 11:21:08 am
Just a thought, the folder isn't set as read only is it?
Did you change the default install directory when you first installed the full app?
Joe Bowden
on Jun 7, 2005 at 1:48:55 pm
It could very well be that you already have Encore 1.5.1 installed.
When you go to Help > About Adobe Encore DVD, what is the build number listed at the bottom of the screen?
-Joe
Chris
on Jun 7, 2005 at 2:33:55 pm
Maybe I do have it....it says DVD Encore 1.5 Build 1.5.1.42735
But if that is the case and I actually was able to animate the menu, the bigger picture is that the program will not burn my DVD. I posted some other posts regarding the error and what I have been doing to try and get to burn.
something tells me i need to try the simplest thing and try and burn that. Also does the transcoding have anything to do with potential errors or the type of DVD Burner? I have the Sony Burner that burns +R and -R.
Just some more thoughts.
thanks.
Chris
Chris
on Jun 7, 2005 at 2:40:35 pm
I just tried to set up the most basic DVD. I inported the transcoded footage, grabbed a menu and set the link to the default play. I checked for errors, then tried to build, but i get that abnormal error deal. I think something bigger is at work here.
Any thoughts?
Thanks.
Chris
