DV PAL to DV NTSC conversion?
COW Forums : Adobe Encore DVD
on May 31, 2005 at 2:25:26 pm
I need to burn 83 minutes of footage onto DVD in NTSC format, which I originally edited as DV PAL on Premiere Pro 1.5. Can I achieve this with the following specs?
Original footage captured as DV PAL on PD170.
DVD player: Matshita DVD-RAM UJ 820S (internal on PC. Set to PAL Region)
Premiere Pro 1.5 used to edit. Timeline as DV PAL
Using Adobe DVD Encore 1.5.
DVD Disc: TDK DVD-R 4.7 GB single sided (hence will be using 2 discs for final DVD package)
Is it just a question of: exporting the DV PAL final movie then start a new Premiere project as NTSC, re-import the avi clip, re-export with new NTSC settings. Start an Encore DVD project with NTSC settings and change the region code of the internal DVD to USA (4 changes allowed my DVD hardware. Then burn DVD. Will this work?
N.B. Encore burning settings states DVD will be burnt to comply for all top dvd players. Does that mean that it will be compatible for US viewing?
Sorry for lenghty query.
Thank you.
Re: DV PAL to DV NTSC conversion?
on May 31, 2005 at 7:58:19 pm
I think you'll end up with playback problems if you use that PAL->NTSC workflow. You should probably convert your PAL assets to NTSC first (e.g. Canopus ProCoder or some other conversion software).
© 2018 All Rights Reserved
