encore error message -2
COW Forums : Adobe Encore DVD
graeme
on May 29, 2005 at 3:38:20 pm
when i go to burn from a img file in encore version 1 it starts to burn and then amlmost straight away comes up with -2 error, error unknown
i have tried to install the ver 1 update from adbobes website but it doesnt seem to work it says cant find the driectory encore was orginally installed in even though the file path for the update is into the same folder as the orginall install, any ideas on this on?
Graeme
Roadkill
Re: encore error message -2
on May 29, 2005 at 8:44:42 pm
Have you checked the build number of Encore? (Help > About Adobe Encore) Maybe it is already 1.0.1.xxxx.
graeme
on May 29, 2005 at 11:24:16 pm
no it is only ver 1.00
any ideas what error -2 is?
Roadkill
on May 30, 2005 at 11:04:32 am
Sorry, but as I replied in your earlier thread, I have no idea what a "-2" error is.
If you can't get the 1.0.1 update to work, it is possible that there is a problem with the Windows registry. For this you should contact Adobe Support who can walk you through the steps necessary to correct the problem.
