FX9: Rating Camera Below Base ISO in Custom EI For Less Noise
COW Forums : Sony Cameras
John Smith
on Jun 23, 2020 at 12:41:19 am
Coming from the Fs7, in Cine EI, I always rate the camera below the base ISO, resulting in a well exposed image in the viewfinder, and an over-exposed image on the MXF file in post. When the exposure is brought back down in post, the shadows are much cleaner than if I shot at the base ISO.
While the FX9, is great in low light, much better than the Fs7,, I have found that using a similar method, of rating the camera at a lower than base ISO, does result in much cleaner shadows, and dark colors in the frame. I’m wondering if anyone else has tested this out and used this method as well.
With the FX9, you have to go about it a little differently. In Cine EI, in order to access the lower ISOs, you have to Internal Record the Lut (yes baking it in), except the Lut that you choose is SLOG3. This allows me to drop the ISO to say 320, thus opening up the iris, and exposing the sensor to more light. With this method, the dark shadows end up much cleaner than if it were exposed at 800, and since the Slog3 Lut is baked in, what you see in your viewfinder is exactly what you get in Post, so no correction needed, like when you rate the Fs7 at a lower ISO.
I’ve also found that rating the 4000 Base ISO lower, say 2000, gave a cleaner image than the 800 at base 800.
Again, I know the Fx9 is pretty clean already, but I add grain in post, and do not like what happens in the shadows on these Sonys, at normal base ISOs.
Let me know if you try this out with similar results, or if this method is not useful at all.
