Media out from NX5U for TV
COW Forums : Sony Cameras
James Davis
on Sep 24, 2013 at 6:16:16 pm
Team,
I have an event to cover and the client would like to be able to make coverage available to local TV.
What formats are acceptable and what might the workflow look like. Thanks in advance.
john lenihan
Re: Media out from NX5U for TV
on Sep 24, 2013 at 6:54:12 pm
I assume that you are not supplying live feed to the TV outlet and are looking for something that they will be able to extract portions for airing.
I would should it 1920x1080 x 60i.
I usually use LPCM audio, when I am editing, but AC3 audio is more easily recognized.
How the TV station wants the format is up to them, however, Most can ingest the AVCHD if you copy the whole file structure from the camera when you give it to them.
Sometimes I dual record onto SD card and onto the FM128 memory and hand the SD card to the client, or tv station in your case.
John
John Lenihan
LeniCam Video Productions
http://www.lenicamvideoproductions.com
