Digital Betacam tape stuck-SOLVED
COW Forums : Sony Cameras
Bret Hampton
on Nov 1, 2019 at 4:12:49 pm
If anyone remembers how to remove a stuck tape I can use your help. The manual says turn a yellow worm gear on the cassette compartment motor, but I cannot see it, even after taking off the right metal panel.
Here's the manual
https://www.manualslib.com/manual/831742/Sony-Dvw-A500p.html?page=23#manual
There's a tiny worm gear underneath control panel tucked up too high so see unless well below deck. You turn the gear until tape comes out (takes a long time)
