Multiple external monitors on FS7
COW Forums : Sony Cameras
Filippo Mira
on May 10, 2019 at 11:39:05 am
Hi guys,
is it possible to connect two external monitors on the FS7 at the same time? Like one in the HDMI output and one in the SDI?
Thank you very much!
Filippo
Blaise Douros
Re: Multiple external monitors on FS7
on May 10, 2019 at 4:21:55 pm
Yes, I believe so, though I've never found it necessary; this allows you to output signal to both an external recorder and a director monitor.
Just to be safe, in case you got to set and it wasn't working, pick up a Blackmagic SDI-to-HDMI micro converter for $60. It has an SDI loop out as well as the HDMI output, effectively acting as a splitter.
Andy Kralik
on Jun 27, 2019 at 4:56:11 pm
It depends on what resolution your shooting. Any 1920x1080 or 720 settings, yes on all outputs. UHD or 4K DCI no. In 4K UHD and 4k DCI formats on the Sony FS7 and FS7 ii the SDI ports become inactive when using those resolutions. The only way you can output UHD, DCI 4K or 4K RAW with SDI on either FS7 models is by adding the Sony XDCA-FS7 adapter. $1998 New at B&H.
