"INPUT SOURCE NOT GOOD" error
COW Forums : Sony Cameras
Jamie Herring
on Jul 26, 2016 at 11:29:12 pm
I edited video from FCP X and exported via Catalyst Browse as an .MXF.
Once saved to disc in the clip folder, I am unable to import that clip from XDCAM Transfer, Import error message reads: "Error reading metadata from file 'P Fit to Fight_1.MXF' (input stream is not good())
I am transitioning from FCP 7 to FCP X. All clips saved from FCP 7 import fine, but nothing saved from FCP X will import.
Only difference between clips is the clip exported from FCP X has Frame Rate 59.94p(59.94p), instead of Frame Rate 59.94p
