Setting & assigning focal depths on a Sony PXW-X70?
COW Forums : Sony Cameras
Toby Mills
on Feb 10, 2016 at 3:44:16 am
Hi. Can anyone tell me if you can set and assign a wide angle and close up shot on Sony PXW-X70? I am filming a subject conduct movement classes and want to be able to use the one camera to shoot both the close up and wide angle shots.
The subject, while moving, is fixed in space and I am hoping I can set both focal ranges, assign them to a button, and then be able to simply click a button to instantly move from close up to wide angle to avoid you using 2 cameras and post-production cropping.
