bad Hiss On XLR
COW Forums : Sony Cameras
Welland Man
bad Hiss On XLR
on Sep 30, 2015 at 12:14:07 am
The hiss is about 40% of the voice
same mic on cable on my canon xa20 perfect any ideas
Craig Seeman
Re: bad Hiss On XLR
on Oct 3, 2015 at 6:40:21 pm
Maybe your mic or camera audio settings.
You haven't provided much technical information to speculate.
Welland Man
Re: bad Hiss On XLR
on Oct 4, 2015 at 12:41:44 am
plugged the xlr in turned volume to 7 Hiss
set on auto Hiss
Cancon xa20 zero hiss any setting
Craig Seeman
Re: bad Hiss On XLR
on Oct 9, 2015 at 2:49:27 pm
I'd like to help but you'll have to provide some technical information.
Depending on the Sony camera there are a number of ways to handle proper mic, input, gain settings all dependent on the mic itself, which is why there's user controllable settings. How it works on another camera may not be relevant. Different camera, different settings.
Michael Slowe
Re: bad Hiss On XLR
on Oct 10, 2015 at 10:34:39 am
First of all, just set all your audio levels to 'auto', in case you have manually set something wrong. Also, if it's a Sony camera, make sure that the little mic switch is set to the phantom power position, and the setting is for an external mic. I'm sure you know all this but it's always best to start with the basics when there are problems. Craig is your man provided to give him all the technical info that he's asking for.
Michael Slowe
