codecs x160
COW Forums : Sony Cameras
Welland Man
codecs x160
on Sep 7, 2015 at 8:39:32 pm
could someone explain the codecs on the x160 180 as only used to mp4 at 35mps (newbie to xdcams)
Craig Seeman
Re: codecs x160
on Sep 8, 2015 at 5:04:02 pm
.mp4 is a container, not a codec. It may contain H.264 but with XDCCAM EX it contains MPEG2.
That's a very broad question.
Generally the camera supports XAVC Intra which is I frame AVC based which may be around 100mbps depending on frame rate
XAVC-L which is a GOP based AVC codec which may be 50mbps or 35mbps
MPEG HD422 which is related to XDCAM HD which is MPEG2 50mbps CBR
MPEG HD420 which is related to XDCAM EX which is MPEG2 35mbps VBR
AVCHD which is AVC GOP based at consumer bit rate of 28mbps or 24mbps
But you can find more detail in the spec sheet. It's not clear at all what info you need and why though.
Welland Man
Re: codecs x160
on Sep 9, 2015 at 3:41:24 pm
thanks so much that explained everything nice one
Blake Porter
Re: codecs x160
on Sep 10, 2015 at 4:45:45 am
A test I ran showed the XAVC 1080P L GOP, 50mb/sp was better in detail, higher resolution than the MPEGHD 422 setting. Example was outside, grass, showed better detail.
Welland Man
Re: codecs x160
on Sep 10, 2015 at 4:56:44 am
what programme do you use to view long gop as none of the ones i got can kmp vlc etc
Blake Porter
Re: codecs x160
on Sep 10, 2015 at 5:02:48 am
Adobe stuff... Premiere Pro CC 2015 etc. and even my old FCP7 XDACM import seems to work with them too. I've just started using the X180. I guess it's the same as the X160 but with WiFi
Don't know what kip or vic is...
