Sony PXW-x70 firmware upgrade available
Craig Seeman
on Jun 4, 2015 at 6:16:50 am
https://www.servicesplus.sel.sony.com/sony-software-model-PXWX70.aspx
I've heard that the XAVC-L clips will now import into FCPX. Recordings made with earlier firmware still does not.
Release notes (English starts on Page 24).
https://www.servicesplus.sel.sony.com/Downloads/SoftwarePLUSReleaseNotes/Re...
Chris Church
Re: Sony PXW-x70 firmware upgrade available
on Jun 5, 2015 at 12:11:57 pm
this is true, tried and tested, only thing is its not 100% correct but all you have to do on the sdxc card is move the XDROOT folder into the same root level folder where you see private and its finally able to read all clips at XAVC Long Hallelujah !!
Chris Church
Producer-Director-Editor
Wire frame Media Ltd
Broadcast Corporate Online
http://www.wireframemedia.co.uk
Craig Seeman
on Jun 5, 2015 at 12:48:53 pm
I'm seeing a scant few reports ranging from it works to same problem as before. Yours is yet another variant.
Chris Church
on Jun 5, 2015 at 1:45:50 pm
Have you tried this variant Craig?
Chris Church
Craig Seeman
on Jun 5, 2015 at 1:49:24 pm
Don't have the camera at this point. The workflow, to date, is too convoluted for fast turnaround work.
Chris Church
on Jun 5, 2015 at 2:02:46 pm
This work around isn't really a work around as such, it's just a matter over dragging over the root folder on the SD card in finder, it takes a matter of seconds, then once you open FCPX it's all there. I guess I've only tried this with shooting a few clips so a days filming may take a few moments longer to drag and drop, the camera is great and love it, more so than the C300 I owned and I'm completely happy at the mo for this to be almost the next best thing to native import. Granted it's still not quite there but a huge improvement to having to transcode everything. Let me know if you want to ask anything else Grant. I guess FCPX may need an update to complete the puzzle??
Chris Church
Craig Seeman
on Jun 5, 2015 at 2:32:12 pm
[Chris Church] "it takes a matter of seconds"
User intervention creates risk.
Import should work like any other supported camera.
Some people aren't having the issue. Apparently others are still having import problems. I wouldn't want to take the professional risk.
Perhaps you need to format the card in camera after firmware update. Perhaps all clips need to be the same setting. I don't think Sony has provided those instructions.
People are reporting varying degrees of success and failure so there's a variable that hasn't been determined yet.
Craig Seeman
on Jun 5, 2015 at 3:01:51 pm
I'm now hearing a couple of reports that the issue is trying to import from the camera directly.
FCPX understands the directory coming from a card reader but has problems if you try to import from the card in the camera.
Chris Church
on Jun 5, 2015 at 3:11:58 pm
Im only speaking from what I've done and seen already which was record 5 clips about 30 seconds each and moved the XDROOT folder over in line I then file imported which I quoted took a matter of seconds just as the C300 MXF EX3 BPAV's and GoPro MPEG's and you're right it should work just like any other import and I'd be a lot happier if I didn't have to do that!! maybe Ian can shed a bit of light on this?? The card had been formatted in the camera and I also reformatted it completey using the SD formatter via their site and still didn't happen so went with moving over the XDROOT folder which works completely. Now I'm not sure what harm this would do as everything required is still contained in the XDROOT folder, the only difference is as mentioned if recording you have to switch it back over to the Private folder, that is where you could come unstuck but you have to be on it so not to let that happen. again if rather that not be the case and I didn't have to switch folders. What's other variants have you seen Craig? And Ian are you aware this is still the case? Has anyone else actually imported and got everything in place without moving over the folders???? Regarding the a matter of seconds I am using a fast MacBook Pro so does help older machine could well be slower. The import was instantaneous.
Chris Church
Craig Seeman
on Jun 5, 2015 at 3:21:12 pm
Are you importing from Camera, Card Reader, Hard Drive (which involves copying of course)?
Chris Church
on Jun 5, 2015 at 3:22:34 pm
From SD card slot on the MBP
Chris Church
Craig Seeman
on Jun 5, 2015 at 3:37:33 pm
I wonder if it would be different if you used a USB card reader.
Chris Church
on Jun 5, 2015 at 3:55:03 pm
Just tried it Craig and no difference, but dragged the folder over again and then worked fine via the card reader.....
Chris Church
Craig Seeman
on Jun 5, 2015 at 4:45:21 pm
This is what one user reports:
Card Reader - In the FCPX import window I see a PRIVATE folder and a private folder. The PRIVATE folder has three files per clip - 1 is a movie icon, 2 is an audio icon, 3 is a still image icon. Importing just the movie file brings in the audio and video flawlessly. The private folder is empty, but viewing it in the Finder it is the top level directory of the card, and encloses all the AVCHD, XDROOT, etc. items.
SD slot on back of iMac - I just see the PRIVATE folder, and it only includes 2 files per clip - the movie file and the still image file - no audio file. But again, the movie file is all that is needed for import. In the Finder all I see is the PRIVATE folder which encloses the AVCHD, XDROOT, etc. - no separate private folder.
They report that BOTH work as is though.
Chris Church
on Jun 5, 2015 at 4:57:56 pm
Yeah they do work as is, by moving the XDROOT over you get rid of all the extra little JPegs all the extra weird audio files etc, you just have all the clips in numerical order, as stated they do import with audio but one strange thing I noticed is that I recorded, ingested went back to record another clip and imported again, it was strange is it didn't recognize the second file. Now again this is just testing and did this without moving the files to the same level as the private folder. I'm waiting for a response from Ian to see if they have anything to say at Sony?.
The variants you mention it just looks messy with all the extra files in the folder and could become confusing if having to CTL click individual files, just my preference to move across the XDROOT, be interested to hear if anyone else has tried it
Chris Church
Craig Seeman
on Jun 6, 2015 at 1:47:21 am
[Chris Church] "Yeah they do work as is, by moving the XDROOT over "
You shouldn't need to move anything.
