sony hxr-nx5u record issue
michael ledford
on May 3, 2015 at 1:02:14 pm
When I trigger the rear record button it gives me the prompt "Attach to external drive." The zoom handle record works fine. How do I get the rear button to trigger normally?
Clint Fleckenstein
Re: sony hxr-nx5u record issue
on May 6, 2015 at 8:22:31 pm
The manual is available here:
https://pro.sony.com/bbsccms/assets/files/micro/nxcam/manuals/FINAL_HXR-NX5...
Page 24 describes the function you desire. Looks like the default is for both buttons to have the same function: record on memory card and optional flash memory unit when the button is pressed. Options split these functions between buttons, and if you don't have a flash memory unit attached I'm guessing it will display the error message you describe.
At risk for sounding rude, I must ask: do you have the manual for your camera? If not, you might want to download and/or print that PDF. Could come in handy. Took me less than a minute to find the answer to your issue.
Cf
michael ledford
on May 6, 2015 at 9:27:31 pm
Thanks. It was a last minute rental. No manual. I finally found the right menu.
Clint Fleckenstein
on May 8, 2015 at 4:18:20 pm
Makes perfect sense. I'm hope I didn't sound like one of those raving "RTFM!" types. :)
Have a good weekend,
Clint
