Shutter on EX3
COW Forums : Sony Cameras
Roger Bansemer
Shutter on EX3
on Jul 16, 2014 at 11:57:37 am
Would someone please explain the "shutter" switch located under the lens area of the EX3. I'm just not getting what it's for.
Roger
Roger Bansemer - PaintingAndTravel.com
Don Greening
Re: Shutter on EX3
on Jul 17, 2014 at 8:32:26 pm
Near as I can tell (the manual is very confusing) when the switch is set to OFF the shutter goes to full auto mode and is affected by shooting format (FPS) and available light. With the switch set to ON then all the shutter adjustment settings become available to the user, including setting the shutter to OFF if that's what you want. With the shutter switch ON you can now choose between the four settings:
- shutter speed
- shutter angle
- extended clear scan (ECS) for shooting TV and computer monitors to stop the rolling of the picture.
- slow shutter (SLS) mode for shooting in low light.
Of course, all four shutter choices have their own individual adjustment settings. Hope this helps.
- Don
Don Greening
A Vancouver Video Production Company
Reeltime Videoworks
http://www.reeltimevideoworks.com
Roger Bansemer
Re: Shutter on EX3
on Jul 17, 2014 at 9:00:36 pm
Thanks very much Don. That helps explain it.
Roger
Elma Okic
Re: Shutter on EX3
on Nov 6, 2014 at 2:46:04 pm
Hi Roger.
Did you get to play with that shutter speed on your EX3?
I am experiencing a very strange problem and cannot get to the bottom of it. Please let me know if you have any thoughts:
https://forums.creativecow.net/thread/142/881732
Roger Bansemer
Re: Shutter on EX3
on Nov 6, 2014 at 4:18:18 pm
Hi Elma,
The explanation that was posted says it pretty good but having said that, I haven't played with it that much and still find it somewhat of a mystery.
Roger
Elma Okic
Re: Shutter on EX3
on Nov 6, 2014 at 4:23:38 pm
Thanks Roger.
I am unfortunately stuck on a weird problem as described in the link (cannot reduce shutter speed slower than 1/60 !) I'm in PAL, and need 1/50 - very strange. Shutter speeds available are: 1/60 - 1/2000 only!
