How to fix problems importing MP4 (SONY EX3) and MXF (C300) into Premiere! Finally!!!!!
COW Forums : Sony Cameras
Juaco Carriquiry
on Apr 30, 2014 at 2:47:25 pm
http://www.calibratedsoftware.com/QXDDownload.asp
http://www.calibratedsoftware.com/MP4EXImport_Mac.asp
http://www.calibratedsoftware.com/MXFImport_Mac.asp
http://forum.cgpersia.com/f37/calibrated-q-osx-full-package-48128/
YES! THERE IS A SOLUTION! (at least worked for me...)
After weeks of research about how to properly import MP4 files (from a SONY EX3) and MXF files (from a C300) in PREMIERE I finally found a solution that DID WORK.
You need to install the Calibrated{Q} MXF or MP4 Importer (depending on what you need) and the Calibrated{Q} XD Decode. BOTH.
You can download a demo version (for both, MAC and PC) and try them. They are not free but it totally worth it.
Calibrated{Q} MXF Import
Calibrated{Q} MP4 Import
If you dont feel like paying or in case of emergency, we can also get them for free here:
I was also having problems (PC) with gamma shift on both MP4 and MXF files during Premiere playback. That was also fixed :)
Im so happy I found this solution!! Hope it works for you!!
Cheers!
Juaco Carriquiry
Audiovisual Producer
Ian Cook
Re: How to fix problems importing MP4 (SONY EX3) and MXF (C300) into Premiere! Finally!!!!!
on Apr 30, 2014 at 3:33:19 pm
Unless you are using a very old version of Premiere it should take EX .mp4s and XDCAM .mxfs natively. I cannot speak for Canon HD422 files but Sony XDCAM and EX files do not require plugins in CS5, CS6 or CC unless they are QuickTime wrapped and being read on a Windows system.
Go with whatever works but again, you should not need anything besides Premiere unless it is very old or the files have been rewrapped for FCP.
Juaco Carriquiry
on Apr 30, 2014 at 3:45:43 pm
Ha! Thanks for your comment Ian! Actually, while I was doing research about this I read a lot of your comments and it was very helpful at the moment! so thanks!
I know that "in theory" it should take EX .mp4 and .mxfs, but in my case (and many others I found around forums) for some reason it doesn't. I just found a solution but I'm not exactly sure whats the problem.
Thanks again
Juaco Carriquiry
Clint Fleckenstein
on Apr 30, 2014 at 5:48:55 pm
I've been bringing in XDCAM EX and Canon files natively with Premiere Pro since CS5.5.
Cf
