Avid to Xdcam backup
COW Forums : Sony Cameras
Mick Reilly
on Mar 30, 2014 at 5:56:40 pm
Avid on PC
I want to back up some clips or sequences to xdcam disc, but I want to maintain the clip or sequence names.
Is this possible?, Would appreciate any help on this
Thank you
Ian Cook
Re: Avid to Xdcam backup
on Mar 31, 2014 at 2:40:53 pm
The original clips can be backed up in the CLIP folder and the Avid library clips and other non-XDCAM files (the op-atom files from Avid Media Files/MXF/#) can be backed up in the User Data folder. if what you need is just a matter of backing up XDCAM file with unique file names, set Free Naming on the device to ON. if you are using the U1/U2 drive this setting is in the drive utility application. On the decks and cameras it's in the operational menu.
