New Pro Applications Update
COW Forums : Sony Cameras
Chris Babbitt
on Dec 17, 2013 at 9:13:14 pm
A new Pro Applications update 2010-02 just appeared in my software updates. Is this the same one that's creating all the misery with XDDAM, or is this a fix?
Ian Cook
Re: New Pro Applications Update
on Dec 17, 2013 at 9:23:28 pm
The issue is with Pro Apps update 1.03 and it only affects Snow Leopard users
Chris Babbitt
on Dec 18, 2013 at 5:20:04 pm
I am on Snow Leopard, so I just want to be sure of what I am doing before I install. I think this is an older update, but I recently re-installed Compressor from my FCP Studio 2 discs, so I think that might be why I am getting this update. Here is what it says:
Pro Applications Update 2010-02 adds compatibility for new camera formats, improves overall stability, and addresses a number of other minor issues. This update is recommended for all users of Final Cut Studio, Final Cut Server, and Logic Studio.
Issues addressed in this update include the following:
Final Cut Pro
• Real-time compatibility with Sony XDCAM HD422 720p24/p25/p30.
• Log and Transfer compatibility with Sony NXCAM SD.
• Control-G not closing the correct gap in the Timeline under the playhead.
• Closed captioning data is now preserved when outputting to AJA Io HD with Print to Tape/Video.
• Performance issue when importing AVCHD with LPCM audio.
• AVCHD thumbnail images in SD are now the correct 4:3 aspect ratio.
• XML export now retains the carriage return when working with text and third-party applications.
• Several memory fragmentation issues have been resolved.
• Localized versions of Final Cut Pro now recognize HDV devices that use the 1080i60/1080i50 FireWire Basic Easy Setups.
• Log and Transfer supports ingesting more than one format recorded to the same SD card.
Motion
• Corrupted display of the camera controls with certain graphics processors.
Compressor
• Adds a compression setting optimized for iPad and iPhone 4.
Color
• Adds compatibility with XDCAM HD422 720p24/p25/p30.
For more detailed information about the changes in an application, choose Release Notes from the application’s Help menu.
Is this going to be OK?
Ian Cook
on Dec 18, 2013 at 5:23:22 pm
this is an old one with mostly FCP 7.0.3 elements. it should be safe but I can't be 100% sure because they may have added something to it since it was first released. copy your QT library folder before you update. you can then revert back if necessary.
