CB export to AVCHD
COW Forums : Sony Cameras
Robin Probyn
CB export to AVCHD
on Nov 19, 2013 at 7:31:49 am
This option is greyed out for me.. how can I make that work.. ?
Ian Cook
Re: CB export to AVCHD
on Nov 19, 2013 at 3:14:11 pm
only works for avchd when you are writing back to media, not for XDCAM/EX/XAVC
if the option is greyed out, it's not valid for the format you are working with. if it's an export requiring the demo version of the Main Concept plugin the option will be active but you'll be reminded at the next step that you are using a trial version. see 'available functions by file format' table in the help..
Robin Probyn
on Nov 20, 2013 at 12:55:36 am
Ok thanks.. can you give a quick description of that plug in.. thanks again
Ian Cook
on Nov 20, 2013 at 3:37:54 pm
the Main Concept plug-in? it's an encoder by Main Concept that is used for all the transcode export options.
Robin Probyn
on Nov 20, 2013 at 10:50:23 pm
Ok thanks..
