HDSDI to HDMI converters
COW Forums : Sony Cameras
jim stamos
on Sep 18, 2013 at 1:03:11 am
im shooting a wedding in a church and there will be a big overflow of guests that cant fit in there. So they want me to run a feed from my ex1r to an hdtv out of the church where guests will watch.
I found this:
http://sewelldirect.com/Spector-by-Sewell---SDI-to-HDMI-mini-converter.asp?...
will it suffice? its reasonably priced.
found black magic and aja converters for a lot more 3-400.00.
ill probably never use this setup again, even if I do, cant put out for the aja or black magic.
input welcome, how long of a run can I go out of the camera and still get good video/audio on the tv.
thx
Steve Kownacki
Re: HDSDI to HDMI converters
on Sep 18, 2013 at 1:24:50 am
Do you have time before the event? (meaning 2 or more weeks) For $45 I'd buy one and try it out; worst case you send it back and buy something known to work with great reviews or you rent one.
HDSDI should go 300meters - don't scrimp on the cable.
Steve
jim stamos
on Sep 18, 2013 at 1:52:16 am
yes, have plenty of time, November 16th
thanks
Dale West
on Sep 18, 2013 at 11:22:53 am
Jim another issue you will need to be aware of is distance. Depending on the quality of your video cable the max distance HDSDI will travel is 200 -300 feet. You should try to measure your run and do some tests with your coax as well
Dale West Video
North Miami, FL
305-588-2683
dale@dalewestvideo.tv
