Will the XDCAM Transfer Application allow me to convert to ProRes
COW Forums : Sony Cameras
Paul Dougherty
on Aug 20, 2013 at 10:36:13 pm
I'm told that FCP 7 doesn't work with 4K XAVC.
Will the XDCAM Transfer Application allow me to convert to ProRes or should I just be happy with Apple XDCAM 422 (the default) which is a form of ProRes?
Paul
Ian Cook
Re: Will the XDCAM Transfer Application allow me to convert to ProRes
on Aug 21, 2013 at 5:03:45 pm
No, our plugins do not transcode to ProRes. Upon import to FCP/conversion to .mov they only re-wrap the MPEG-2 XDCAM video. If you need ProRes you can use Compressor or FCP on the Transfer-generated .mov files. The XDCAM codecs perform well in FCP so it will depend on what you prefer or if you have to work in ProRes for other reasons.
JFYI the Apple implementations of the XDCAM codecs are not a form of ProRes. They are very different codecs with different profiles.
Hope this helps..
Don Greening
on Aug 21, 2013 at 10:06:08 pm
[Paul Dougherty] "I'm told that FCP 7 doesn't work with 4K XAVC"
That's because Apple officially stopped supporting FCP7 over 3 years ago. Even though FCP7 is "dead" lots of folks, including me, still use it.
- Don
Don Greening
A Vancouver Video Production Company
Reeltime Videoworks
http://www.reeltimevideoworks.com
