can't install XDCAM EX Log & Capture Plugin 1.2 into Mac OS X 10.7.5 and FCP 7.0.3
COW Forums : Sony Cameras
Hugh Chaloner
on Aug 20, 2013 at 9:47:42 pm
As the subject says - I'm unable to install the plugin, I get an error message saying
" can't be installed in this disk - Final Cut Pro 6.0.3 or higher is recommended ..."
I have 7.0.3 installed on OSX 10.7.5
Any ideas?
Thanks Hugh
Ian Cook
Re: can't install XDCAM EX Log & Capture Plugin 1.2 into Mac OS X 10.7.5 and FCP 7.0.3
on Aug 21, 2013 at 4:58:50 pm
You may have an older version of the plugin-- there were two different ones, one for 6 and one for 7. It's also not supported under Lion. You should maybe consider Content Browser or XDCAM Transfer. All the existing XDCAM plugins have been replaced by Content Browser, and if you don't want to purchase a CB version 2 serial (20.00) you can still use version 1.1 for free.
XDCAM Transfer is also discontinued but has been tested under Lion and operates normally. Look under 'Legacy Applications' at our main download site-- http://www.sony.com/xdcam-downloads
Content Browser 1 (supports XDCAM and, optionally, NXCAM/AVCHD): http://www.sonycreativesoftware.com/contentbrowser1
Content Browser 2 (XDCAM, NXCAM, AVCHD): http://www.sonycreativesoftware.com/contentbrowser
